2004 Chevy Tahoe Serpentine Belt Installation
2004 CHEVROLET TAHOE
85,000 MILES • V8 • 4WD • AUTOMATIC
EDSTAFFORD
I have removed my upper serpentine belt, when I removed the alternator. I can't get the belt back on. They doesn't seem to be a pulley tensioner. Where there is usually a tensioner, there is only a fixed pulley. The belt goes around this pulley, the alternator, the water pump, the crank, the fan, and the power steering pump. They all seem fixed to the block. Nothing to loosen to get slack, and no tensioner to pull back to get slack. I've done this many times on other cars, but am missing something help. Please help.
Nov 17, 2009 at 7:53 PM
EDSTAFFORD
[quote:308ffb0699="edstafford"]Engine Mechanical problem
2004 Chevy Tahoe V8 Four Wheel Drive Automatic 85000 miles
I have removed my upper serpentine belt, when I removed the alternator. I can't get the belt back on. They doesn't seem to be a pulley tensioner. Where there is usually a tensioner, there is only a fixed pulley. The belt goes around this pulley, the alternator, the water pump, the crank, the fan, and the power steering pump. They all seem fixed to the block. Nothing to loosen to get slack, and no tensioner to pull back to get slack. I've done this many times on other cars, but am missing something help. Please help.[/quote:308ffb0699]
I found the issue. The tensioner is built into the water pump pulley. It looked to be fixed, but it wasn't. Belt is back on.
Nov 17, 2009 at 8:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry we didn't get to your problem. But very happy that you got on your own.
Nov 18, 2009 at 10:34 AM
