2004 Chevy Tahoe
2004 CHEVROLET TAHOE
75,000 MILES • V8 • 4WD • AUTOMATIC
DALODARRYL
? is how long can i drive my tahoe if i disconnect my two front o2 sensors or park it tell i get new ones in, i was told too change my oil and filter plus my plugs, is that need to be done, my tahoe idoles rough and going throw gas lots, ,exhaust stinks, blows out lite black smoke, can u give me a heads up on what too do?
Dec 15, 2008 at 12:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Driving the vehicle in this condition will only cause poor fuel mileage. So you can drive it for a few weeks until you can get the issue fixed if the time is needed..
Sounds like you have a faulty catalytic converter on your exhaust. At 75,000 miles, it is not a bad idea to get the plugs and wires changed. Oil and filter should be changed every 3,000 miles. The 02 sensors will cause bad fuel mileage when faultybut would not cause a smell. I suggest having an exhaust shop look at your catalytic converter(s) to see if one or more need replacing.
Dec 15, 2008 at 12:50 AM
DALODARRYL
what can a guy do if about the catalylic converter if there is no shop in town, should i go ahead and disconnect the o2 sensors, and wait for new ones too be odered in or just leave them on, i am going to go ahead and change the oil & filter, plus the plugs, how can i check the o2 sensors too see what side needs to be changed?
Dec 15, 2008 at 2:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Unless you know welding, there isn't much you can do. Disconnecting the O2 sensors will not help you any. I don't think you need new sensors...
Dec 15, 2008 at 11:46 AM
