My brake fluid/system was ruined due to a faulty resevoir cap and condensation build up. The brake fluid was drained yet the rear fluid would not drain, since then the master cylinder(refurb) has been replaced yet the brake fluid is still not reaching the rear. I've done some research and I've been told it is the air lock in the proportion valve. Does that sound right and what is that? How would you replace? Also the resevoir had a green build up around it it has since been cleaned- Do you recommended replacing that altogether?
Jan 12, 2009 at 2:29 PM
