I just bougth 24 in rims for my tahoe. On the freeway it start to shake well the stearling wheel. what do i do to fix it.
Jun 10, 2009 at 12:53 PM
DOCFIXIT
CERTIFIED EXPERT
Where the tires balanced? Rims torqued properly?
Jun 10, 2009 at 1:37 PM
BERNIEM
MEMBER
When you left the place when you got them on,
did you hit the freeway? Or ...
Used or new tires? Or did you buy the rims
with tires on it already from someone?
If used with tires on them, could be a bad tire.
Or old owner hit a hole good enough where it
is bent a hair and will always wobble.
If new, then balanced wrong or rims not correct.
