2002 Chevy Tahoe Injector troubleshooing
2002 CHEVROLET TAHOE
99,750 MILES • V8 • 4WD • AUTOMATIC
DIGGERDPILOT
Hi, hope you saw the donation.
I have a 2002 Tahoe, 5.3L Flex fuel, that has started throwing two codes, a P0301, and a P0301pending. The SES light is steady below about 20MPH, and flashes above it or in heavy throttle. I have replaced plugs and wires, and flopped the coil packs with another cylinder, and still get the same message. The injector clicks with a stethoscope, and I did replace the fuel filter, and tried with some throttle body cleaner. No luck, still have the miss.
I pulled the rails, and wouldnt you know it, NAPA gave me the wrong injector, and it was after hours. I replaced everything to get to work and am picking up the right one tomorrow.
My question is although I should have flopped two injectors when I had the rails off, is there anything else I should do to troubleshoot this?
And, I am guessing the injector is not entirely plugged, and letting enough fuel by to cause the pending code, but not enough to fire well at higher throttle, thus tripping the hard miss code.
Can an injector needle break? While I have the rails off, should be they cleaned with some cleaner, or anything else other than the #1 injector replacement and a fresh set of o-rings?
Thanks for the help! Appreciate the site.
Digger Treinish
Feb 21, 2008 at 8:09 PM
FLEXY5
  • 512 POSTS
Typically when injectors fail, it is a mechanical failure. It is rare that they fail electrically. The pulsing you are hearing is most likely the electromagnetics of the injector. It either has something stuck in it or it's just worn out. If you replace the injector and still have a problem, post back and we'll get this thing figured out. Thanks for the donation, too.
Feb 21, 2008 at 9:38 PM
DIGGERDPILOT
Well, that did it. So far, so good. Thanks a million, I will remember the site, it is a great idea!
Feb 22, 2008 at 4:18 PM
