I started to drain the coolant system for a system flush and could only get about 7 of the 14 quarts in the system to drain out. I poured the coolant back in until I figure out what's up, and the system shows to be full.
What do I need to do other than removing the reservoir cap and opening the drain valve?
I removed the upper radiator hose and it did not help.
I started the engine and ran it until the engine reached temperature - still nothing additional came out beyond a trickle.
I started this exercise because the system started running about 245 F under highway loads, and I thought the thermostat was stuck. Is the trickle I'm getting the flow through the thermostat air bleed valve?
How should the draining normally be done?
May 10, 2009 at 10:50 PM
