Hello Ron !!
The codes:
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0101 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
Well looks like your Mass Air Flow sensor its dirty or malfunctioning, remove it and clean it (do it with care) clear the codes and see if they comeback.
Go to your local auto store and get electrical contact cleaner. Spray it thru the honey combo and over the diodes to get it good and clean. It will dry pretty quickly
thanks a lot for your donation and good Luck!
let us know if that solve your problem !
Jan 21, 2008 at 3:53 PM
