2001 Chevy Tahoe replacing A/C high pressure switch....
2001 CHEVROLET TAHOE
145,000 MILES • V8 • 4WD • AUTOMATIC
JCY110
I have a 2001 chevy tahoe and the A/C cuts out when the vehicle is running at low speeds when its very hot outside. Last time it cut out while driving slowly I stopped the vehicle and with the engine running opened the hood. After a few minutes the A/C clutch started clicking then stayed engaged and the A/C was working again making me believe that the HI PRESSURE SWITCH is probably failing. I ordered a new switch and see that its held in place by a snap ring. After evacuating the system can I remove the snap ring and switch without removing the compressor? Will any oil leak out when its still mounted in the Truck? I have a 2001 chevy tahoe and the A/C cuts out when the vehicle is running at low speeds when its very hot outside. Last time it cut out while driving slowly I stopped the vehicle and with the engine running opened the hood. After a few minutes the A/C clutch started clicking then stayed engaged and the A/C was working again making me believe that the HI PRESSURE SWITCH is probably failing. I ordered a new switch and see that its held in place by a snap ring. After evacuating the system can I remove the snap ring and switch without removing the compressor? Will any oil leak out when its still mounted in the Truck?
Oct 17, 2010 at 5:59 PM
DOCFIXIT
  • 18,828 POSTS
If you can get to snap ring O.K. leave comp. on engine no oil loss will occure. But most likely problem is faulty fan clutch not pulling cool air through condenser
Oct 18, 2010 at 3:17 PM
JCY110
I already replaced the clutch fan and A/C still shut down when its very hot out.
Oct 18, 2010 at 6:49 PM
