1999 Chevy Tahoe TRANSFERCASE
1999 CHEVROLET TAHOE
198,700 MILES • V8 • 4WD • AUTOMATIC
OSVAL99
I HAVE A ISSUES WITH MY 4 WHEEL DRIVE WHEN I PUT IN 4 WHEEL DRIVE & MAKE LEFT OR RIGHT TURN IT SEEMS AS IF THE TRUCK WAS STUCK & CANT MAKE THE TURNS. WHEN I TAKE IF OFF THE I HEAR LOUD BANG & FEEL A DROP LIKE IF WHERE ON TOP OF JACK THEN DROPED. I AM ALSO GETTING A LEAK FRM THE REAR OF TRANSFER CASE I HAVE CHANGED THE SEAL & JOKE TAKEN IT TO DIFF PLACES I AM ADV NEED NEW TRANS CASE BUT THE GUY WHO CHANGED THE JOKE (MACHINE SHOP) SAID THAT THERE IS A BUSHING INSIDE THAT ALSO NEEDS TO BE REPLACED & COULD BE DONE WITH OUT TAKING OUT THE TRASFERCASE IT THAT TRUE.
Sep 22, 2010 at 9:53 PM
HMAC300
  • 48,601 POSTS
there is a bushing that the yoke rides in. But it's on ly on the rear and not the front. If you are getting a bang then you may have soemthing seriously wrong with the t-case. If one mechanic says it should be revuilt then get another opinion. But also check yoru front wheels to make sure there isn't a problem with the automatic wheel lockups. The bushing can be replaced, not easily and if you ahve the taken care have a pro do it. you'll need either a specialized puller to grab it and take it out or be able to split it to remove it. OF course if you can take the extension housing off then you can just drive it out and drive a new one in as well as installing a new seal.
Sep 25, 2010 at 9:04 AM
