schrader valve seal can it be replaced
1999 CHEVROLET TAHOE
110,330 MILES • V8 • 4WD • AUTOMATIC
JIMBOB048
If the shrader valve seal has gone bad on the high side of the A/C system, can it be replaced or do you have to replace the whole hose assembly?
Oct 25, 2008 at 10:47 AM
SQM
  • 6,383 POSTS
The shradder valve should have an O-ring that keeps it sealed. The O-ring can be replaced with a correct type and size O-ring. Keep in mind that there are specific type of O-rings for A/C lines and that is what needs to be used.
Before changing the O-ring you will have to evacuate the A/C system.
Here is a video of how to discharge the AC system properly:
https://youtu.be/4EqdrBVb0sY
Thank you.
Nov 5, 2021 at 8:38 AM
