1999 Chevy Tahoe hard shift
1999 CHEVROLET TAHOE
160,000 MILES • V8 • 2WD • AUTOMATIC
DEWAYNE ALEXANDER
when the torque converter lock it hits hard everthing elce shift ok .the check eng lite it on the code is the camshaft sensor p340
Nov 23, 2009 at 5:23 PM
Chances the light and the shifting problem have nothing to do with each other. As far as the camshaft sensor, it may start giving you trouble. THe shifting problem needs to be checked by a trans mechanic. THe torque converter locing clutch may be going bad. If that is the case, it will need replaced.
Nov 29, 2009 at 6:47 PM
