1999 Chevy Tahoe Front tires
1999 CHEVROLET TAHOE
88,000 MILES • V8 • 4WD • AUTOMATIC
LOWRIDER08
I have a new set of Michelin Radial Tires on my Tahoe. On my way home from the tire store when I apply the brakes I have a shake in the steering wheel. I had a set of Michelin on the Tahoe before and had no problems. They also had to replace a wheel stud because they had to break it to get the lug nut off. Im not sure which wheel either. Could it be the tires or could they messed up or could they have messed up the caliper.
May 30, 2009 at 7:35 PM
replacing the stud shouldn't have anything to do with the caliper, so I say no to that. If it only happens when you use the brakes and no other time, it sounds like you have a warped brake rotor. Also, make sure the wheels have been properly tightened.
Let me know what you find.
Jun 9, 2009 at 11:24 PM
