Hi Marie,
We need to start with basically the same info as above. However, if you could get a video of the noise then that will help narrow this down.
I would suggest we start with finding out if the engine has any metal in the oil.
Let's drain the oil into a clean pan and look in the bottom of the pan for any metallic shiny pieces. It will look like glitter in the bottom of the oil pan. You can also cut the filter apart if you want to but that is not needed.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Next we need put oil back in and drive the vehicle. I don't expect this will fix the issue but clearly if we start to get some of the acceleration power back then we are on the right track.
The lack of power and noise when accelerating normally points to a motor that is locking up but there could be other issues.
Does this ticking noise happen all the time or does it stop when you let off the gas? What about when just sitting at idle, does it make the noise then or do you have to be moving?
Let's start with this and see if you can get the video and check the oil and we can go from there. Thanks
Sep 1, 2021 at 2:03 PM
