1999 Chevy Tahoe coolant leak
1999 CHEVROLET TAHOE
62,000 MILES • V8 • 4WD • AUTOMATIC
TAHO99
Hi i have a 99 tahoe with 62,000 i have replace water pump and upper and lower hoses and i still have a coolant leak i look under the truck and i see coolant at the bottom of the time cover
Oct 25, 2009 at 2:58 PM
MATHIASO
  • 1,209 POSTS
remove the timing cover, behind it is located freeze plug or coolant plug . the plug might come off and coolant may leaking from there.New freeze plug woul do the job plug look like this:
https://www.2carpros.com/forum/automotive_pictures/46384_RHCoolantPlugs1a_1.jpg
Oct 25, 2009 at 4:20 PM
TAHO99
it looks like it come from around the intake but not sure
Oct 25, 2009 at 4:33 PM
MATHIASO
  • 1,209 POSTS
A coolant pressure test will be need to locate the exact place of the leak.it may be a crack head.
my understanding was under the timing cover.
but, have a coolant pressure done with leak detector would make the job easier.
Oct 25, 2009 at 4:51 PM
