1998 Chevy Tahoe Oil cooler gasket
1998 CHEVROLET TAHOE
SHARKBAITHAL
Engine Cooling problem
1998 Chevy Tahoe V8 Four Wheel Drive Automatic
Replaced leaking oil cooler gasket. Gasket kit from Dealer has larger O-ring and small flat disk (paper type gasket). The disk fits over the 2 bolts that secure housing to block and also lines up over smaller diameter internal part of cooler that extends into block. There was not a disk in the cooler when I dropped it down. Is the disk for this application (98 Tahoe, 5.7, 4WD) or is it only for limited applications?
Jan 20, 2010 at 5:03 PM
Chances are if there wasn't one there when you removed it, there are mulitiple applications.
Jan 21, 2010 at 9:53 PM
