1997 Chevy Tahoe water pump
1997 CHEVROLET TAHOE
20,300 MILES • V8 • 4WD • AUTOMATIC
MONTESSRACER
how do u get the clutch fan of of the water pump?
Jan 10, 2010 at 10:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable. Remove the radiator fan shroud. Remove the drive belt, if necessary. Remove the four fan clutch-to-water pump pulley nuts and lift out the fan/clutch assembly.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1414.jpg
Remove the fan clutch bolts and separate the fan from the clutch. To install: Install the fan on the fan clutch and tighten the bolts to 17 ft. lbs. (23 Nm). Position the fan/clutch assembly on the water pump pulley. Tighten the nuts to 18 ft. lbs. (24 Nm). Install the fan shroud. Connect the battery cable.
Jan 10, 2010 at 10:49 PM
