1997 Chevy Tahoe Rear seal
1997 CHEVROLET TAHOE
126,000 MILES • V8 • 4WD • AUTOMATIC
MRS.SCHAEFER
There is a leak from the back end of my vehicle. My father-in-law says it may be the rear seal. How can I confirm this and how do I fix it without taking it in?
Sep 25, 2009 at 12:04 PM
JEEPFAN
  • 135 POSTS
which seal did he say rear main seal or tailhousing seal? is it leaking engine oil or transmission fluid(which is red in color)?
Sep 25, 2009 at 4:41 PM
MRS.SCHAEFER
Rear main seal. Fluid dark, not red.
Sep 25, 2009 at 10:06 PM
JEEPFAN
  • 135 POSTS
youll probably not be be able to do the repairs yourself. it involves removing the oil pan id ask around to find a reputable shop
Sep 27, 2009 at 12:32 PM
PEAR69
  • 1,482 POSTS
The rear main seal is not hard to change and removal of the oil pan on these engines is not necessary. However it is hard to access. You must remove the transmission for this repair.
To determine if the rear seal is leaking, you can remove the peep hole plug on the bell housing (there are three of them) and to see where the leak is coming from.
Oct 3, 2009 at 2:30 AM
