I have a 97 Chevy Tahoe. I am loosing fluid somewhere out of the radiator which eventually causes the truck to over heat. I have to add fluid to the radiator every other day. There is no water in the oil and none in the transmission, the only place I can see fluid dripping out is from a little nozzle that looks like an overflow on the pasengers side firewall of the engine compartment. I am assuming the heater core is on the other side of the firewall. The heater works fine and no visible problems such as smoke or steam coming from the vents and nothing leakig inside the cab and no antifreeze smell. Any suggestions as to my problem. I have also replaced the radiator cap and I see no fluid coming from the water pump. The car runs fine and cool as long as I keep adding antifreeze & water. When the engine is turned off I can hear a hissing sound but it is the coolant dripping from the little nozzle on the firewall.
Thanks for your time.
Sep 8, 2008 at 5:32 PM
