1997 Chevy Tahoe Brake lights
1997 CHEVROLET TAHOE
14,000 MILES • V8 • 4WD • AUTOMATIC
KTAHOE
Brake lights have stopped working, as well as emergency blinkers. I've checked all the fuses and relays. I DO have a trailer brake installed. The brake switch is also ok. Directional signals in rear work fine. Does anyone have any suggestions??
Jun 3, 2008 at 9:26 PM
MASTERTECHTIM
  • 4,750 POSTS
check the white wire from brake switch to directional signal switch up column, if you have power there then replace the turn signal switch. this is causing both your problems. the brake lights run through the hazard portion of the directional switch so when you are taking a left turn and have foot on brake the right brake light will stay on and the left one will blink.
Jun 4, 2008 at 6:08 AM
