What size lower ball joints does a 1996 4-dr Chevy tahoe 5.7L Vin "R" use? I have been getting two different answers...
May 13, 2009 at 8:26 PM
ZACKMAN
CERTIFIED EXPERT
I don't have measurement, but they differ in terms of how they are mounted. Either 2WD or 4WD. If 4WD, either bolt-on or pressed fit. If pressed fit, either 45.79mm or 47.89mm.
May 19, 2009 at 9:56 PM
CDJ58190
MEMBER
the size of ball joint used is based on the type of control arm. If you check the arms to see if they are a stamped one piece steel or if they are two piece welded where the piece the ball joint presses into looks like its a cast steel piece welded into the control arm. the welded arms use the larger of the two ball joints
