vacuum leak around intake head
CHEVROLET SUBURBAN
CRACHEL613
I have a 97 chevy suburban,150 k miles.I just had my intake head replaced and when my car was put back together, it is now running rough. The car shut off when the brake is applied. You have to keep your feet on the gas and brake at the same time. Can you give me some insight on what might have not been connected properly. Thank you
Nov 10, 2007 at 6:51 AM
FOADIARD
[quote:f6b4923d92="brad1125"]I have a 2004 F-150, I had the alternator replaced at 43,000 miles. The day after it was replaced ,while driving down the road every instrument in the cab shut off. The engine was still running like nothing was wrong, after about 15 seconds it all came back on. It has done this several more times since then.[/quote:f6b4923d92]
did you check see if all your wiring was tight and secure????
Aug 27, 2007 at 5:21 PM
FORDTRUCKBUM
  • 19 POSTS
Go in and make sure that all the leads and grounds are securely reattached, it sounds like a ground might be loose or not making good contact after the replacement of the alternator.
Aug 27, 2007 at 5:35 PM
MERLIN2021
  • 17,250 POSTS
Vacuum hoses! who did the repair? And do you mean an intake manifold? or a head was replaced? If it idles get a can of spray gumout, spray around the vac lines and intake, when the idle changes, you have located the leak!
Nov 10, 2007 at 7:12 AM
