rough start when cold too much fuel and air?
CHEVROLET SUBURBAN
SUPERTACKYMAN
  • 4 POSTS
ok. 1991 3/4 ton 2wd chev suburban 5.7l tbi 180k miles
ran great up until a week ago.
went to start it and a loud hissing noise eminated from tbi. also seemed to be putting in way too much gas. idles and drives really rough when cold. coughs and sputters and smokes until warmed up then runs fine.
I originally was told it was the coolant temp sensor so i replaced that
replaced: coolant temp sensor- no change
replaced throttle position sensor- no change
replaced map sensor- no change
replaced o2 sensor- no change
removed and cleaned vaccuum openings on tbi - no change
no vacuum leaks noticed.
throttle plates are not sticking or worn
new fuel and air filter less than 5k miles ago
allways changed oil on time if not before
once it warms up- it runs fine but a bit rich. no ses light
however!! if i unplug the coolant temp sensor all the problems go away. except i get the ses light blinding me.
all parts were replaced with new parts
cap and rotor, wires and plugs look fine and were new 9 months ago. she allways runs cool and has never overheated.
also checked connections and wires on all replaced parts and they seemed fine.
please help!! this problem just SUDDENLY started (she ran like gangbusters 2 days before. i went out of town and when i came back and started my baby this all began) and im too poor for a mechanic.
im out of ideas the last thing i can think is the ecm
also replaced the spark controller in the distributer a few months back.
Nov 17, 2007 at 8:05 PM
BMRFIXIT
  • 19,053 POSTS
[quote:7b57964cad="supertackyman"]ok. 1991 3/4 ton 2wd chev suburban 5.7l tbi 180k miles
also replaced the spark controller in the distributer a few months back.[/quote:7b57964cad]
try the EGR
take it out and clean it
Nov 17, 2007 at 10:33 PM
BLACKOP555
  • 10,386 POSTS
you just about narrowed it down to the MAF or AIS same part different name. also the IAT may be a tad bit dirty.
SUPERTACKYMAN
  • 4 POSTS
[quote:278276e893="blackop555"]you just about narrowed it down to the MAF or AIS same part different name. also the IAT may be a tad bit dirty.[/quote:278276e893]
if the maf/ais is that the bolt on plunger thet attatches (screws into) to the back of the tbi? has a 4 prong connector?
if so allready replaced that too.
Nov 17, 2007 at 11:22 PM
BLACKOP555
  • 10,386 POSTS
it should be located near the air intake hoses, usually just look for wires going into the hoses or the air fliter housing!
Nov 18, 2007 at 9:20 AM
SUPERTACKYMAN
  • 4 POSTS
this morning i checked the EGR also removed and cleaned out the EGR solenoid. put it back on and started it and it ran just fine.
drove it around a lil bit and then put away my tools and made sure that everything was put on tightly etc.
now it wont run again!!!!!
AAAAAARRRRRGGGH!
now my temp gauge inside the cab dosent move.
its just getting worse by the day.
Nov 18, 2007 at 5:22 PM
BMRFIXIT
  • 19,053 POSTS
[quote:5265d2a061="supertackyman"]this morning i checked the EGR also removed and cleaned out the EGR solenoid. put it back on and started it and it ran just fine.
AAAAAARRRRRGGGH!
its just getting worse by the day.[/quote:5265d2a061]
temp gauge
just look for the sending unit wire may be off
did the egr had a lot of carbon
it want start know why did u check what missing spark fuel pulse......
Nov 18, 2007 at 6:26 PM
