Rear Diff replacement
CHEVROLET SUBURBAN
WFMDFM
I have a 2001 Suburban 5.3l 1500 4wd. At 159K I needed to replace the rear axle(loud griding and would not move unless in 4wd). At 163K I am experiancing the same issue. The diff that went in was used with 65K on it. Is there a history of these failing? I do tow a trailer from time to time but would think that this machine should handle it. The ratio is 3.73 am I able to change it and would that help? Other than this issue this has been a great car with little trouble from day one.
Jul 28, 2007 at 6:45 AM
KD202
  • 5 POSTS
[quote:d4f5e1f287="wfmdfm"]I have a 2001 Suburban 5.3l 1500 4wd. At 159K I needed to replace the rear axle(loud griding and would not move unless in 4wd). At 163K I am experiancing the same issue. The diff that went in was used with 65K on it. Is there a history of these failing? I do tow a trailer from time to time but would think that this machine should handle it. The ratio is 3.73 am I able to change it and would that help? Other than this issue this has been a great car with little trouble from day one.[/quote:d4f5e1f287]
Unfortunately my diff on our 03 Suburban Z71 went out at 56k.. it was 600 to fix, I have found this is a prob and reported to NHTSA... others had the same issues, sorry for your probs :(
Jul 29, 2007 at 2:18 PM
CHRIS_KOLAR
  • 10 POSTS
I have noticed that on my rearend failure happened after I changed a tire. It was damaged and the set had 20k on them. The new tire was the same type but new. 5k later the rear end is broken. I believe the tire size difference however small was just enough to overheat the lube and cause a failure.
Aug 4, 2007 at 3:12 AM
