radiator leak
CHEVROLET SUBURBAN
STATII
Suburban, 1999, 140,000, 5.7l
Just under the upper radiator hose there is a connection where the coolant lines screw into. It has a flange fitiing of sorts that the coolant lines screw into. It is leaking there. The locking flange is only finger tight. Do I tighten the flange to stop the leak. Seems like a mighty "frail" fitting for this application. Also, there seems to be no gasket.
Thanks
Doug
Apr 17, 2007 at 4:40 PM
BUM454SS
I have the exact same leak. Did you ever remedy this problem. And if so, would you mind sharing it with me. Thanks for your time. [email protected]
Jan 23, 2008 at 2:19 PM
