power window
CHEVROLET SUBURBAN
BJWRIGLEY
My power window controls on the driver side of the vehicle shorted out the vehicle. It is 10 degrees. I tried to roll down the window and the power window switch pushed into the panel this caused the car to die. Power was lost to the car, the windows, radio & door locks only. The headlights and interior lights are working. No fuse was blown.
There was a drain on the battery just before the car died.
chevy suburban 1990
Feb 9, 2007 at 10:08 AM
MIKE H R
  • 3,094 POSTS
check the fuseable link and circuit breaker. they are in the fuse panel. before you do, disconnect the window control on the driver side and check leads with a static light to see if you have power to the switch.
Feb 19, 2007 at 10:47 PM
