2005 Chevy Suburban spare tire lock removal
2005 CHEVROLET SUBURBAN
58,000 MILES • V8 • 4WD • AUTOMATIC
LEE1272
When trying to remove the spare tire lock, insert key turn nothing moves !! Does the lock cylinder just come out ,or the black bracket around it !! Sprayed WD-40 around everything -- no luck !! Thanks !!
Feb 15, 2010 at 10:08 AM
LEE1272
[quote:b210f13a51="lee1272"]Warranty problem
2005 Chevy Suburban V8 Four Wheel Drive Automatic 58000 miles
When trying to remove the spare tire lock, insert key turn nothing moves !! Does the lock cylinder just come out ,or the black bracket around it !! Sprayed WD-40 around everything -- no luck !! Thanks !![/quote:b210f13a51]
Looks like I solved my problem !! With much tender persuasion, the lock cylinder came out---Two "O" rings around it--Chevrolet should have put a little lube on them---works great with a little silicone grease on them !!
Feb 15, 2010 at 3:21 PM
