2005 Chevy Suburban four wheel drive
2005 CHEVROLET SUBURBAN
110,000 MILES • V8 • 4WD • AUTOMATIC
TURFSTOMPERS
I was using four wheel drive high last night in the snow and a noticeable whining noise appeared about 20 miles into my trip from the p/s front wheel. i disengaged the 4 wheel drive and the noise went away. This morning, out of curiousity, i tried my 4 wheel drive in low. I put vehicle in neutral as always, pushed the button for low and then put my vehicle in drive. it acted like i was still in neutral. i put it back into 2 mode and all is well. obviously there is a problem, what are your thoughts?
sam
Feb 12, 2010 at 10:40 AM
MERLIN2021
  • 17,250 POSTS
A whine is almost always caused by a bad hub bearing, start there.
Feb 13, 2010 at 10:11 AM
TURFSTOMPERS
WHY WOULD THAT CAUSE MY 4 WHEEL DRIVE TO NOT ENGAGE?
Feb 15, 2010 at 9:41 AM
MERLIN2021
  • 17,250 POSTS
You may have 2 problems! A whine as I said is almost always a bearing problem, but probably wont stop 4X4 from engaging, but there is a Tech bulliten on your truck for your exact symtoms. Drove thru snow and had 4X4 trouble, check your email, and I will send a PDF on the bulliten. Let me know if the symtoms in it mirror yours!
Feb 15, 2010 at 1:55 PM
