2004 Chevy Suburban Rear windshield wiper motor
2004 CHEVROLET SUBURBAN
103,023 MILES • V8 • AWD • AUTOMATIC
JBAKAF
My rear windshield wiper does not work. I replaced the motor and it still does not work. When I turn the wiper on you can hear the motor knocking on the inside like it is trying to work. I put the old motor back on and it does the same thing. Are both motors bad or is there some sort of short?
Mar 8, 2010 at 1:53 PM
CARADIODOC
  • 34,308 POSTS
There's a "clinker in yer thinker". If you're hearing knocking, the motor is running so nothing is shorted. This would be typical of a linkage that has come apart, but there aren't any linkages for your system. It's all built into the motor / gear package assembly. The size of the motor assembly isn't very substantial, so it stands to reason parts inside it are going to break, especially if the gears are made of plastic. Was that a used motor you installed? If so, it likely has the same problem as your old one. If you bought a new motor assembly, be sure the wiper arm is bolted tightly to the splined shaft.
Also, if all you replaced was the motor that bolts to the assembly, the problem is in the gear package, not the motor itself. Those are about the only possibilities as the entire system is self-contained.
Mar 22, 2012 at 5:45 PM
