Blower Motor only works on high speed?
2003 CHEVROLET SUBURBAN
12,000 MILES • V8 • 2WD • MANUAL
JOHN DICKEY
The blower fan on my 2003 suburban only works on high speed. I suspect the blower motor resistor to be the problem. Where is it located and is it easily replaced?
Thanks,
John
Dec 16, 2007 at 10:03 AM
MERLIN2021
  • 17,250 POSTS
Most of the time it's mounted on the a/c heater plenum, next to the blower, yes fairly simple, unplug connector remove screws, pry out, snap new one in and plug in...
Dec 16, 2007 at 11:50 AM
I agree with MERLIN2021, here is the location of the blower motor speed resistor which is right next to the blower motor so you can change it out and fix the problem. Check out the images (below). Let us know if you need anything else.
Nov 6, 2024 at 1:13 PM
