2001 Chevy Suburban Electical gremlins
2001 CHEVROLET SUBURBAN
JOP'S SHOP
Electrical problem
2001 Chevy Suburban V8 Four Wheel Drive Automatic
Battery discharges overnight, hooked amp guage on battery terminal draw is.2 amps with everything off can not reduce by pulling fuses. Also Instrument cluster does not work, changed with used one same problem, changed ignition switch same problem. Any ideas?
Aug 26, 2010 at 6:01 PM
HMAC300
  • 48,601 POSTS
it may be your ABS motor if you have ABS. those can be fixed for about $150 or so. But have a pro check for a draw
Sep 2, 2010 at 1:39 PM
