[quote="Dr Loot"]okay there is only one thing left, but first of all let's eliminate the problems we've already solved:
1. Radios do malfunction and some of the channels go out like forward and backwards and right and left, but that's not the problem here because your husband replaced the radio.
2. You stated that your husband removed the speakers from the left side and installed them in the right side and vice versa and they worked, so obviously it's not the speakers.
3. so now we have narrowed it down to only two things:
a. The wiring going to the left side door, and;
b. The fader switch that you failed to mention.
Due to the fact that it is a 2000 it is unlikely that the wiring is malfunctioning, unless you are not telling me the hole story, like you've had some kind of work performed on the vehicle door console ext. So the only other problem it could be is the fader switch. so check out those two possibilities and let me know which one it was. And thanks for responding, I am tired of answering questions and nobody responses.[/quoteDALIA1974]OK, MY HUSBAND HAS ALREADY CHECKED THE WIRING WITH A TEST LIGHT AND THERE IS CURRENT GOING THROUGH, SOME TIME BACK I HAD THE DRIVER DOOR WINDOW REPLACED DUE TO A BREAK IN, SO WE'RE NOT SURE IF WHEN THEY REPLACED THE WINDOW THEY MAY HAVE DROPPED IT ON THE SPEAKERS AND MADE CONTACT SOMEHOW. YOU THINK MAYBE IT'S THE BUILT IN MANUFACTURES AMP THAT MAY HAVE BURNED? THANKS FOR ALL YOUR HELP!
May 21, 2009 at 12:25 PM
