2000 Chevy Suburban pulsation in breaking
2000 CHEVROLET SUBURBAN
CCOUFAL
Brakes problem
2000 Chevy Suburban V8 Four Wheel Drive Automatic
My 2000 1500 Suburban suddenly took on a very heavy pulsation in the rear during breaking. there is also a knocking in rythym with the pulse in the pedal. i am pretty capable of troubleshooting and repair but this is puzzling. The pads are worn and in need of replacement but i do not believe the pads are the extent of the problem. the pedal does a pretty deep dip every revolution as if the rotor was significantly thinner in one area. i do not drive this car as often as other family members so i am not sure how quickly it started.
Feb 26, 2010 at 7:28 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation.
This will be a warped brake rotor, if you get a vibration in the steering as well it will be fronts, if you get a body vibration check the rears.
mark (mhpautos)
Feb 26, 2010 at 7:45 PM
