I have a leak on the drivers side of the radiator?
1999 CHEVROLET SUBURBAN
80,428 MILES • V8 • 2WD • AUTOMATIC
SEAN_P_HOGAN
I have a leak on the drivers side of the radiator. It is leaking where the cooling line goes into the top of the radiator. I actually looks like the bolt like apparatace that holds the threads on is leaking behind that part. Please Help
Jul 25, 2008 at 7:02 PM
MASTERTECHTIM
  • 4,750 POSTS
If you have a leak on the driver's side of the radiator where the cooling line goes into the top of the radiator, it's likely related to the transmission cooler lines.
Jul 25, 2008 at 7:09 PM
SEAN_P_HOGAN
All I had to do was take the transmission cooler line off and re seal it.
Jul 26, 2008 at 7:50 AM
MASTERTECHTIM
  • 4,750 POSTS
i apoligize. i thought you were talking about the part that is inside the radiator. that part has a big nut that attaches it inside the radiator and will leak coolant externally and it looks like the nut can be tightened or resealed but it cant. i try to answer as accurately as possible with the information i am given. i assumed you were leaking coolant, not transmission fluid. my mistake. i should have asked you for a better explanation. we do try our best to give fast accurate answers and unfortunately something like this happens. again i apoligize. tim
Jul 26, 2008 at 11:22 AM
JLSSMOFFITT
I currently have the same problem with my 99 suburban and was wondering how sean_p_hogan took "the transmission cooler line off and re seal it". Hopefully that will work for me. It would definitely beat buying a new radiator....
Oct 28, 2008 at 6:58 PM
