Engine Cooling problem
1999 Chevy Suburban V8 Two Wheel Drive Automatic 150K miles
We noticed the water temperature was changing from 190 degrees to red line hot and then back to190-210. it varied almost constantly.
Replaced the radiator cap. It had an 18 PSI and was replaced with an 18 PSI cap with relief lever. That seemed to stop the problem but the car cooled down in the meantime.
A leak near where the AC would depense condesation water has a red tint to it and is a bit sticky.
Is this probably the water pump causing this problem?
Do you have a procedure for replacing the water pump?
Thanks,
Bill Berry
Thanks,
Bill Berry
Aug 21, 2010 at 1:52 PM
