1999 Chevy Suburban low brake pedal
1999 CHEVROLET SUBURBAN
ACE58
  • 4 POSTS
I had a rear wheel cylinder seal failure. The pedal dropped down, the dashboard brake light came on, but I still had front brakes. I decided to convert to rear disc brakes instead of repairing existing drum set up, with a complete kit from EGR. I continued to drive the vehicle, on a limited basis, until the parts arrived, adding fluid as necessary. I installed the complete kit and bled all 4 calipers. I still have a low pedal, and the brake light is still on. How can I remedy situation? Thanks
Jul 30, 2008 at 9:18 PM
BLACKOP555
  • 10,386 POSTS
if the fluid got too low it could be that youve gotten air in the master cylinder and it will have to be bench bled before anything else can commence
will pedal get hard with key off even a slight bit harder.
Mar 15, 2021 at 11:46 AM
ACE58
  • 4 POSTS
Yes, it is marginally better with key off.
I bled lines at master cylinder and at each wheel, left rear-left front-right rear-right front, with no improvement in pedal or elimination of light on dash
BLACKOP555
  • 10,386 POSTS
pump it up the pedal till its hard. from there push about 200 pounds of force on the pedal and hold it, does pedal stay or does it continue to sink lower, if it goes down master cylinder may be leaking internally.
ACE58
  • 4 POSTS
With the hydra-boost, the pedal doesn't pump up but, it does maintain a constant level, although quite low. While running, the same level is maintained and when "200 pounds pressure" is applied the front wheels lock up. The rear discs stay cool indicating they are not working.
A friend said an air bubble in the ABS could cause a problem but, wouldn't air be eliminated through bleeding? Thanks for your help.
BLACKOP555
  • 10,386 POSTS
i was saying put on the pressure so if it goes down then your loosing brake fluid through a leak causing the pedal to be low.
air can cause a low pedal, but abs has to be bleed with a scan tool not the conventional techniques.
ACE58
  • 4 POSTS
Thanks for reply. Been away. What type of scan tool is used for ABS brake bleeding? Is this a dealer only tool?
BLACKOP555
  • 10,386 POSTS
for the price it might as well be
