1999 Chevy Suburban Fan clutch & disappearing coolent
1999 CHEVROLET SUBURBAN
218,000 MILES • V8 • 4WD • AUTOMATIC
POPEYE.54
When is a fan clutch no good? 2. Coolent disappearing, with no visible leaks?
Apr 19, 2009 at 3:54 PM
PEAR69
  • 1,482 POSTS
Your lower intake gaskets are probably leaking coolant. It may be leaking inside of the engine and getting into your oil - or - leaking where it evaporates before it can be detected. Coolant in oil will destroy your engine quickly. The fan clutch on your engine rarely goes bad. But if it does the fan will not rotate of move enough air through the radiator - thus causing overheating.
Apr 19, 2009 at 10:43 PM
