1999 Chevy Suburban ABS System - Can it be disconnected?
1999 CHEVROLET SUBURBAN
171,000 MILES • V8 • 2WD • AUTOMATIC
TIMOTHYB
My ABS wheel speed sensor and wire are melted. With the knowledge that I would replace the rotor, the inner and outer bearings, the seal, the caliper, pads, rotor, flexible brake line and hardware, and bleed all four wheels, will my brake system work, albeit without ABS, if I do not purchase the ABS wheel speed sensor, wire and connector?
Jun 23, 2008 at 7:43 PM
BLACKOP555
  • 10,386 POSTS
yes it will work just fine only the abs system will not function.
i dont recommend it.
Jun 23, 2008 at 8:41 PM
