1999 Chevy Suburban
1999 CHEVROLET SUBURBAN
177,000 MILES • V8 • 4WD • AUTOMATIC
BLESSEDONE333
Got a 454 BIG BLOCK 78.4L chevy truck
I've replaced the wires, plugs, cap & rotor, timed to factory, put new injectors, cleaned heads, replaced catalytic converters and MAP sensor and it still runs rough at idle 800 rpm and has very poor acceleration off the line. once it's up to speed it's okay - like past 35 miles an hour but it's still dogging it after I did all that replacement parts. I have a code reader also and it's not coming up with anything on it that I have not already replaced. please help
Mar 14, 2010 at 4:58 PM
Hi blessedone333, Welcome to 2carpros and Ty for the donation.
Clean out the idle air control valve, also clean the mass airflow sensor with approved cleaner and test the throttle position sensor, also clean out the EGR valve
Mar 14, 2010 at 8:33 PM
BLESSEDONE333
we think it might be a faulty camshaft to crankshaft corraltion error
we have a code reading scanner but it's slow going as to why the rough running after replacing all of the items I listed
Mar 14, 2010 at 9:01 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 15, 2010 at 5:03 PM
