Yes, I have a multimeter and know how to use it. The washer motor does not run.
I have now dis-assembled the washer assembly and have learned that both motors have the same reading, ohm =~ 3.5 when detached from the wiring. So the motor does not appear to be shorted or the fuse would also blow.
Both appear to be in equal physical condition.
Voltage readings from the plug for each when not attached to the pump but with the switch activated;
Front - From 0 up to ~ 11.5 but very intermittent
Rear - ~ 12.5 V, pretty steady
I have checked each fuse for front and rear and they are both good. Ohm readings equal and fine. Voltage readings in the fuse block are correct for both. Are there any other fuses, relays, circuit breakers, etc to check?
It is apparent that the switch or maybe another fuse/relay/circuit breaker are not putting power from the washer switch on the joy stick to the pump. Maybe the switch is bad. Is there an easy way to check the joy stick? All other functions, turn signals, headlights, etc work fine on the joy stick.
Thanks,
John
Is there something else to check? If so, where and how? Anything else to check
Oct 18, 2010 at 4:37 PM
