1997 Chevy Suburban engine want turn over
1997 CHEVROLET SUBURBAN
170,000 MILES • V8 • 4WD • AUTOMATIC
JAYPEE
  • 17 POSTS
My surban want turn over. I have replaced , Ignition Control Mod , Ignition Coil, distributer cap,pick up coil,Rotor Ingtion, Timin Chain, Fuel Filter and Battery.Had the fuel pump check and was told I was geeting enough fuel..Also had a code comback P1351 , which is the code for Ignition Control Mod.Si with all these part replaced could it be my computer that is out.I was told the ECM may need to be replaced.any responce would be helpful..
thanks
Mar 20, 2008 at 6:38 PM
SERVICE WRITER
  • 9,123 POSTS
It does not crank?
Or
It does crank and does not start?
"Crank" meaning the engine is spinning over but not starting.
Mar 20, 2008 at 6:43 PM
BMRFIXIT
  • 19,053 POSTS
all the parts changing did you check for spark
do a spark test and check if the injector pulse
check TPS volts make sure its not in flood mode
Mar 20, 2008 at 6:51 PM
JAYPEE
  • 17 POSTS
IT CRANKS BUT DOESN'T START.
Mar 20, 2008 at 6:52 PM
JAYPEE
  • 17 POSTS
yes' i'm getting sparks from the number 1 and 8 spark plug
Mar 20, 2008 at 6:53 PM
BMRFIXIT
  • 19,053 POSTS
did you try to spray starting fluid
check TPS volts
Mar 20, 2008 at 6:59 PM
JAYPEE
  • 17 POSTS
yesssir , I tried the starter fluid. what is TPS VOLT
Mar 20, 2008 at 7:02 PM
BMRFIXIT
  • 19,053 POSTS
did it start with starting fluid
tps :
throttle position sensor
Mar 20, 2008 at 7:06 PM
JAYPEE
  • 17 POSTS
NO SIRRRRRRRRRRRR
Mar 20, 2008 at 7:07 PM
BMRFIXIT
  • 19,053 POSTS
firing order ?
https://www.2carpros.com/forum/automotive_pictures/99387_57_chevy_1.jpg
Mar 20, 2008 at 7:08 PM
JAYPEE
  • 17 POSTS
firing order , what do you mean by that.
Mar 20, 2008 at 7:11 PM
BMRFIXIT
  • 19,053 POSTS
i sent the picture with it for the firing order
i noticed also you send that you have spark @ 1 and 8
what about the rest do u have spark
on all
Mar 20, 2008 at 7:21 PM
JAYPEE
  • 17 POSTS
spark
Mar 20, 2008 at 7:30 PM
BMRFIXIT
  • 19,053 POSTS
I had included the firing order may be you want to check that
also we had problem with coils and distributor cap we replace them all the time on that engine
may be you should check that too
Mar 20, 2008 at 7:43 PM
JAYPEE
  • 17 POSTS
okay thanks for the feedback. i will look into tomorrow when i get home. i'm think he didn't put the wires on correct now. but i did replaced the dist.cap and pick up coil already. i'm thinkin he just put the plug wires on wrong.but if he didn't beside the TPS , what else can I look at.
Mar 20, 2008 at 7:50 PM
BMRFIXIT
  • 19,053 POSTS
check / replace the coil
not the pick up coil
its the black thing on the picture
Mar 20, 2008 at 8:01 PM
JAYPEE
  • 17 POSTS
I took it today to auto zone and the gentleman check it for me. he said it look like it was good , but I bought a new one anyways.just didn't have time to put it on. after i check the wires tomorrow i , replace the coil.
Mar 20, 2008 at 8:08 PM
JAYPEE
  • 17 POSTS
also , I remember last week..when I pulled up to a red light or stop sign I noticed on my gauges , the oil pressure and battery gauges would drop off.then when I started to move again they would rise up.on friday night comin from fishing at one stop when I came to a intersection the batter gauge drop dwon so much that all my light when dim. then the next day I start havin this issue with my truck. could this have something to do with they way my truck is actin.i had the alternator check and it passed several times
Mar 20, 2008 at 11:57 PM
BMRFIXIT
  • 19,053 POSTS
check the coil and the firing order
Mar 21, 2008 at 6:09 PM
JAYPEE
  • 17 POSTS
i replaced the coil and i had two wires in wrong .the number 2 and 4 wasn't in the correct firin order and I found out the number 8 wasn't all the way on. i had it towed to a shop today and the dude told me it was the feul pump went out. after I sprayed the starter fluid in it .it never started , so could the fuel pump be out or is he tryin to pull as fast on on me
Mar 21, 2008 at 6:18 PM
BMRFIXIT
  • 19,053 POSTS
you said that the fuel pump was checked and you had pressure
well did they check the pressure and what it you have for pressure ??/
it is very possible that the fuel pressure is low
Mar 21, 2008 at 6:24 PM
JAYPEE
  • 17 POSTS
i don't know , but when he unscrewded the cap off the line when after he checked the pressure fuel was still comin out. the only reason why i;m concered , is when I told him about the code that was pulled up P1351 , he said he could get any codes b/c the car want run and without it runnin he can't confirm that code. i told him about me pourin gas in the body and the startin fluid he just laughed and said it the feul pump.
Mar 21, 2008 at 6:35 PM
BMRFIXIT
  • 19,053 POSTS
Well with out fuel pressure it will NOT run you need pressure
and
where did you put the starting fluid
did he tell you what was the fuel pressure
and #
as for the codes your ECM save the codes
you can get them whether the its running or not
as long as you get the truck running let him do it
get price $$$$
Mar 21, 2008 at 7:35 PM
JAYPEE
  • 17 POSTS
I sprayed some startin fluid in the throttle body and it never made my truck run.we also put gas in their also and it never made the truck run. the pressure readin was 30. the price he game me was 186 for all the parts and 300 for labor. for towing and dignostic it all come down to 650
Mar 21, 2008 at 8:26 PM
BMRFIXIT
  • 19,053 POSTS
Fuel pressure should be 55-61 PSI
as for the price it far
good luck
Mar 21, 2008 at 8:46 PM
JAYPEE
  • 17 POSTS
oaky...thanks for all the help... :D
Mar 21, 2008 at 9:04 PM
BMRFIXIT
  • 19,053 POSTS
let me know when you pick it up
Mar 21, 2008 at 9:05 PM
JAYPEE
  • 17 POSTS
i have one more question, well I'm going to pick up my truck and repair it my self. my question is when after I replace all those ignition parts , I did another check on my spark plugs. i still have red spark. should i have a blue spark or am I just stressed out behind this issue
Mar 24, 2008 at 9:57 AM
BMRFIXIT
  • 19,053 POSTS
1st thinks 1st you need the truck to start /run
and after that you can check the spark quality
and replace coil if you wish
Mar 24, 2008 at 12:46 PM
JAYPEE
  • 17 POSTS
okay , I just put on the fuel pump, filter and my truck is still doing the same thing.could the computer or chip be fried. what else it for me to do.even when i put on the timin chain could it still be off timin..i've changed the hot wire from the battery to the computer and all the coils.
Mar 31, 2008 at 2:21 PM
BMRFIXIT
  • 19,053 POSTS
OK
lets take a step back
and start form the basic
redo check the basic
check for a good spark
check fuel pressure
and check for water in the fuel system check injector pulse
if you have all three then check compression
don’t overlook something u think it was tested do
check it again
let me know
Mar 31, 2008 at 5:14 PM
JAYPEE
  • 17 POSTS
okay , right now I'm at work so I will keep you updated. injectore pulse and compression where do I look for that..
Mar 31, 2008 at 6:19 PM
BMRFIXIT
  • 19,053 POSTS
Compression is done by removing a spark plug and using a compression gauge
crank engine
injector pulse remove injector connector and you can use a light bulb # 194
band the wire end on the bulb to fit in the wiring plug and crank engine watch for it to flash
check fuel pressure too
get a sample of the fuel and test it
Mar 31, 2008 at 6:30 PM
JAYPEE
  • 17 POSTS
okay , i will try it..but as for as the fuel goes , I emptied out my tank when I replace the fuel pump.i can go to auto zone and buy a compression gauge, where is the injectore connector located..should i by a fuel relay..thats the only thing i didn't replace.
Mar 31, 2008 at 6:41 PM
BMRFIXIT
  • 19,053 POSTS
good u empty the fuel out
Lets make sure u have a good spark
injectors are under the upper intake manifold
(the plastic plenum .)
lets clear the coil out the way
we had so many problems with them coils and cap + rotor
lets start at the spark and make sure we have a good and strong spark
Mar 31, 2008 at 7:15 PM
BMRFIXIT
  • 19,053 POSTS
[quote="BMRFIXIT"]good u empty the fuel out
lets start at the spark and make sure we have a good and strong spark 1
fuel pump relay
if the fuel pump working when 1st key on then relay should be ok
Mar 31, 2008 at 7:17 PM
