When you start from a dead stop the transfer case will grind unless you just bearly add throttle. This only happens in 2WD. If you place it in 4WD it will not grind. Once you take off in 4WD and shift it into 2WD it will not grind again until you come to a complete stop.
Any advise on where to start is greatly appreciated!
Thanks.
Thanks.
Mar 15, 2008 at 1:13 PM
