headlight dimmer switch
1994 CHEVROLET SUBURBAN
183,000 MILES • V8 • 4WD • AUTOMATIC
SHANAHAN05
  • 4 POSTS
The dimmer switch wont switch from high to low, the blinkers work and the wipers work. i need help... i bought a new turn signal handle but that didnt fix the problem, how do i change the dimmer switch? there is no way that i have found to get cover off behind the steering wheel to get to the dimmer switch, i pulled the steering wheel off but dont know how to get plastic cover off any help would be appreciated. thank you.
Matt
Feb 16, 2010 at 10:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is your vehicle equipped with the tilt column or the standard column? which lights are working, the high beam or lo beam? may be a faulty fuse or relay instead of switch.
Feb 16, 2010 at 10:46 AM
SHANAHAN05
  • 4 POSTS
it has the tilt column, the lights are always on dim, when i pull the handle back to engage brights nothing happens..... no click nothing. i have checked all fuses and all relays are in good woking order, checked that already, i need to know how to pull the cover off of the steering wheel column so i can get to the switch that controls bright/dim. the plastic piece is broken... that switches back and forth. the column is all one piece. no screws to take out, i need to know how to get that off so i can replace that broken part
thanks.
Feb 18, 2010 at 10:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will actually have to remove and disassemble the entire steering column to replace the switch. I can give some detailed steps if you would like. Does it have the column shift or the floor shift?
Feb 18, 2010 at 10:53 AM
SHANAHAN05
  • 4 POSTS
column shift...i would appreciate any help available
Feb 18, 2010 at 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1699.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_538.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname3_207.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname4_105.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname5_47.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname6_24.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname7_11.jpg
Feb 18, 2010 at 4:33 PM
SHANAHAN05
  • 4 POSTS
Thank you so much for all the help, i can now fix my wife's suburban.
thanks again...
Feb 20, 2010 at 10:00 AM
