1994 Chevy Suburban 1994 chevy suburban
1994 CHEVROLET SUBURBAN
144,000 MILES • V8 • 4WD • AUTOMATIC
JEFRIC
The suburban is running rich and has no pwer , can not get over 40 mph with the throttle wide open at 3000 rpm . It will not go over 3000 rpm. I have replaced the o2 sensor, ignition module, coolant sensor, throttle positioning sensor, and fuel filter. the computer is not showing any codes.
Feb 6, 2008 at 12:02 PM
MERLIN2021
  • 17,250 POSTS
How is the convertery? Or exhaust restriction? Use a vacuum gauge and see if your initial reading is between 16-22Hg, then watch as engine runs, if gauge drops slowly you may have an exhaust or converter problem....Does the check engine light come on when you turn the key to on?
Feb 6, 2008 at 12:05 PM
