Well, I've been slow at getting back. The whistling noise was there before I changed out any parts... Up to date these are the things I've replaced in the order they were done...
1. New Spark plugs
2. Added Heet to the fuel
3. New O2 sensor (had error code 44)
4. New fuel injector on the TBI as well as a new gasket on the injector assembly / TB (I completely removed the injector assembly.)
5. Added fuel injector cleaner to the fuel.
6. New fuel filter
7. Siphoned out all of the gas (about 5 gallons)
8. Added new fuel. (about 3 gallons)
The whistling noise is gone...
The test drive... spits and sputters, will not make it up a hill, stalls, gas petal floored (nearly) truck not moving, the jumps forward...(spit and sputtering)
Since most of all of the parts are original on her, I'm assuming the fuel pump could be the cause and the next item to change out. Or the Fuel pressure Regulator sensor on the TBI? Maybe?
Like I said in my previous post I have never had anything wrong with her before other than minor issues like the belt, battery, brakes, water pump, spark plugs, power steering pressure hose, and a clogged muffler? (she had dogged down before, but after we changed the muffler out she was fine)..
Thanks for all the advice given and to come!
Laura
Jan 3, 2019 at 5:54 PM
(Merged)
