1993 Chevy Suburban Starter
1993 CHEVROLET SUBURBAN
CFEBOUND
  • 4 POSTS
Electrical problem
1993 Chevy Suburban V8 Two Wheel Drive Automatic
Just replaced the starter and when I try to hook up the negative battery cable it attempts to start. What could be wrong?
May 5, 2010 at 8:30 AM
Starter solenoid could be sticking or a faulty ignition switch.
May 5, 2010 at 9:10 AM
CFEBOUND
  • 4 POSTS
[quote:43e78f10a6="rasmataz"]Starter solenoid could be sticking or a faulty ignition switch.[/quote:43e78f10a6]
could it be the neutral safety switch
May 5, 2010 at 9:23 AM
The power comes from the ignition switch thru the NSS and then to starter. The NSS has power only when the ignition switch is in the cranking positon-If you hook up the starter correctly-your problem is the ignition switch-
How many small terminals do you have on the starter if you have 2 switch it around and see what happens.
May 5, 2010 at 9:27 AM
CFEBOUND
  • 4 POSTS
[quote:8648fde7bd="rasmataz"]The power comes from the ignition switch thru the NSS and then to starter. The NSS has power only when the ignition switch is in the cranking positon-If you hook up the starter correctly-your problem is the ignition switch-
How many small terminals do you have on the starter if you have 2 switch it around and see what happens.[/quote:8648fde7bd]
I have two one has an S and the other a R used them both and it does the same thing. Could it be a wire is touching some where.
May 5, 2010 at 2:15 PM
The purple wire goes to the S terminal the other wire goes on the R which is the ignition by pass if it continues to crank -the solenoid is shorting out if not were right back to the ignition switch.
May 5, 2010 at 4:33 PM
CFEBOUND
  • 4 POSTS
[quote:058d0f5f0c="rasmataz"]The purple wire goes to the S terminal the other wire goes on the R which is the ignition by pass if it continues to crank -the solenoid is shorting out if not were right back to the ignition switch.[/quote:058d0f5f0c]
The purple wire has another wire leading from it but it was never hooked up on my old starter. By the way where does the purple wire lead to?
May 6, 2010 at 8:53 AM
