Having trouble removing front rotor from bearing hub
1993 CHEVROLET SUBURBAN
JSAUSAU
having trouble removing front rotor from bearing hub. this is a 2500 heavy duty suburban. any help will be greatly appreciated.
thanks,
js
Sep 25, 2009 at 8:11 PM
SQM
  • 6,383 POSTS
After all the bolts removed, you will need to use a wheel puller to remove the brake rotor from the hub.
I have attached the replacement procedure below.
Thank you.
Oct 14, 2021 at 1:47 PM
