1992 Chevy Suburban Hard shifting
1992 CHEVROLET SUBURBAN
315,000 MILES • V8 • 4WD • AUTOMATIC
JAKENEEDSHELP
  • 6 POSTS
When i shift into reverse, primarily when vehicle facing downhill, I hear a loud clunk. I suspect the transmision. So i had 2 diff friends listen to the clunk. They hear it from the rear end of the vehicle.So I replaced the U joints in hopes. That didnt do anything to help. Still shifts hard. But sound comes from the rear of the vehicle. Any help would be greatly aprreciated. How do I fix/check a rear end or tell if its the trans???
Sep 27, 2010 at 10:21 PM
MADMIKE1735
  • 951 POSTS
check for freeplay in your pinion.... (grab the yolk and look for freeplay in and out).... let us know what you find there.
Sep 27, 2010 at 10:26 PM
JAKENEEDSHELP
  • 6 POSTS
I did that when i redid the u joints. It has a little bit of play but not very much. Old guy I was with said mine looked normal.
Sep 27, 2010 at 11:01 PM
JAKENEEDSHELP
  • 6 POSTS
How much freeplay is normal?
Sep 27, 2010 at 11:03 PM
MADMIKE1735
  • 951 POSTS
anything you can see, or feel is to much.... the endplay is set to such tight tolerances, that any play felt will verify a problem.
Sep 27, 2010 at 11:06 PM
JAKENEEDSHELP
  • 6 POSTS
Id say there was a least a 1/4 inch play. So whats my next step? And thank you
Sep 27, 2010 at 11:23 PM
JAKENEEDSHELP
  • 6 POSTS
And why would the CLUNK sound come from the rear????
Sep 27, 2010 at 11:25 PM
MADMIKE1735
  • 951 POSTS
remove the rear diff cover... it is possible that a tooth has broken on either the ring gear, or spur gear... that would def. cause a clunk... let us know what you find.
Sep 29, 2010 at 7:12 AM
