My Suburban runs rough around 1000 to 1500 rpm in gear, in neutral, and in park. When taking my foot off the pedal it dropps down to around 200 Rpm running real rough then smooths out and goes back up to about 500 to 600 rpms idle. Periodically, it will die over and over again and it is hard to restart, once started it will die again if I let the rpms drop down or if I put it in gear without holding the rpms up at around 1.5k to 2k rpms to get it going without the engine dying, engine runs very rough during this time. Eventually after maybe 10 times of restarting or driving for a while without stopping it quits dying and goes back to just running rough at 1 to 1.5 k rpms and dropping down to 200 rpms running rough, smoothing out then raising back up to 600 or 700 rpms to idle as described before. I've changed spark plugs, air and fuel filter. Have not changed distributor or wires. Could this be a fuel pump or TBI injector problem? or does it sound more like a timing / spark issue. Any help greatly appreciated.
Jul 4, 2008 at 6:45 PM
