[quote:e00bb2d035="Jacobandnickolas"]I'm sorry, I didn't realize they still used carbs in 91. However, I've been in the business for nearly 30 years, so I remember them well.
As far as the timing advance, it doesn't change the timing that much to cause that much of a difference at low RPM's. The only thing I can think of to cause that much of a power loss is a major vacuum leak or a really weak spark from the ignition causing the fuel not to fully burn. At 100K miles, the engine shouldn't be worn out and the timing chain should still be fine, and you tried both gas and LPG so it isn't a fuel pump problem or carb problem. Has the vehicle ever just died on you and then restarted? Has this problem ever happened in the past where you lost that much power?[/quote:e00bb2d035]
Has the vehicle ever just died on you and then restarted? No, this has never happened to my truck.
Has this problem ever happened in the past where you lost that much power?[/quote]
Yes, In my garage there is a small ramp, and I have to enter the garage with some speed, When I try to stop in the middle, there is a point when I can´t go up, and I have to go back and enter again with some speed.
The spark plug cables are two years old,I changed the spark plugs about six months ago. But I dont´use much this truck, only weekends and on hollydays. That´s why it has a low mileage after almost 20 years of use.
What I have noticed lately is thay the rpm´s are very high when the engine is idiling with gasoline. Maybe 900 or 1000 rpm idle. I don´t have a tachomenter.
installed.
Hiow can I check a vacuum loose??
Thanks for your time.
Jan 26, 2010 at 3:13 PM
