1989 Chevy Suburban oil pressure gauge
1989 CHEVROLET SUBURBAN
144,000 MILES • V8 • 2WD • AUTOMATIC
BRIAN.HEATHER
  • 6 POSTS
I have a 89 chevy suburban that after about 10 miles of driving or so the oil gauge drops to 0 at idle in drive only if you put it in park it stays at 15 and when your on the gas in drive it stays at about 18 when you start it and for the first 10 miles the pressure it right at 30. it runs pretty good but after the pressure drops if you try to start it, well it takes a while whats my list of things to check and replace first.
thanks
brian
Feb 11, 2008 at 5:00 PM
MASTERTECHTIM
  • 4,750 POSTS
i would definately start by replacing the oil pressure sender, also check to make sure your fuel pump relay is working, it sounds like you have a combination of the 2 problems.
Feb 11, 2008 at 5:03 PM
